Ana içeriğe geç
ASUS K200MA-DS01T Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: adım 1, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement, Back Panel: adım 1, 2 resimden 2.
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Hard Drive Replacement: adım 2, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement: adım 2, 2 resimden 2.
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Hard Drive Replacement: adım 4, 3 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement: adım 4, 3 resimden 2. ASUS K200MA-DS01T Hard Drive Replacement: adım 4, 3 resimden 3.
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: adım 5, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement, Keyboard: adım 5, 2 resimden 2.
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Hard Drive Replacement: adım 6, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement: adım 6, 2 resimden 2.
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
  7. ASUS K200MA-DS01T Hard Drive Replacement, Battery: adım 7, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement, Battery: adım 7, 2 resimden 2.
    • Flip the computer over so that the side with the motherboard (large green piece) is laying face-up.
    • Remove the following screws from the middle and far ends of the battery:
    • Three 4mm Phillips screws using a Phillips #0 screwdriver.
    • The battery will be located closest to the screen.
  8. ASUS K200MA-DS01T Hard Drive Replacement: adım 8, 3 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement: adım 8, 3 resimden 2. ASUS K200MA-DS01T Hard Drive Replacement: adım 8, 3 resimden 3.
    • Gripping the wider left section, lift the battery up and away from computer.
  9. ASUS K200MA-DS01T Hard Drive Replacement, Fan: adım 9, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement, Fan: adım 9, 2 resimden 2.
    • Locate the fan, two screws and two color coded wires in the bottom left corner of the computer.
  10. ASUS K200MA-DS01T Hard Drive Replacement: adım 10, 1 resimden 1.
    • Remove the following screws from the fan:
    • Two 4mm screws using a Phillips #0 screwdriver.
  11. ASUS K200MA-DS01T Hard Drive Replacement: adım 11, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement: adım 11, 2 resimden 2.
    • Firmly pull colored wires away from wire slot.
  12. ASUS K200MA-DS01T Hard Drive Replacement: adım 12, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement: adım 12, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • After removing both the screws and color coded wires, lift fan out of place.
    • Tools such as spudgers or tweezers may be used for fan removal.
  13. ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: adım 13, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement, Hard drive: adım 13, 2 resimden 2.
    • Four 4mm Phillips screws using a Phillips #0 screwdriver.
  14. ASUS K200MA-DS01T Hard Drive Replacement: adım 14, 2 resimden 1. ASUS K200MA-DS01T Hard Drive Replacement: adım 14, 2 resimden 2.
    • Remove by sliding hard driving right and away from the computer using the tag on the right side.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Terrinda
526 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G5, Bruce Fall 2018 CSU Fullerton, Team S2-G5, Bruce Fall 2018 üyesi
CSUF-BRUCE-F18S2G5
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 510
