Ana içeriğe geç
ASUS K200MA-DS01T Keyboard Replacement
Neye ihtiyacın var
  1. ASUS K200MA-DS01T Keyboard Replacement, Back Panel: adım 1, 2 resimden 1. ASUS K200MA-DS01T Keyboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • With the opening facing you, flip the laptop over and remove the following screws from the back panel:
    • Six 4mm Phillips screws using a Phillips #0 screwdriver.
    • One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
  2. ASUS K200MA-DS01T Keyboard Replacement: adım 2, 2 resimden 1. ASUS K200MA-DS01T Keyboard Replacement: adım 2, 2 resimden 2.
    • Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
  3. ASUS K200MA-DS01T Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the following screws:
    • Two 4mm Phillips screws using a Phillips #0 screwdriver.
  4. ASUS K200MA-DS01T Keyboard Replacement: adım 4, 3 resimden 1. ASUS K200MA-DS01T Keyboard Replacement: adım 4, 3 resimden 2. ASUS K200MA-DS01T Keyboard Replacement: adım 4, 3 resimden 3.
    • Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
    • You may have to use one spudger to wedge between the back panel and keyboard while using another to pry it open in a different spot.
  5. ASUS K200MA-DS01T Keyboard Replacement, Keyboard: adım 5, 2 resimden 1. ASUS K200MA-DS01T Keyboard Replacement, Keyboard: adım 5, 2 resimden 2.
    • To disconnect the keyboard connectors from keyboard and back panel, gently pull wide keyboard connector out.
    • Gently pull the narrow connector away from the keyboard.
  6. ASUS K200MA-DS01T Keyboard Replacement: adım 6, 2 resimden 1. ASUS K200MA-DS01T Keyboard Replacement: adım 6, 2 resimden 2.
    • Now that the keyboard connectors are unplugged, pull the keyboard off and away from the back panel hinges.
Sonuç
Aliyah Malapit
199 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G5, Bruce Fall 2018 CSU Fullerton, Team S2-G5, Bruce Fall 2018 üyesi
CSUF-BRUCE-F18S2G5
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 190
