Ana içeriğe geç
ASUS K43SV SSD Replacement
Neye ihtiyacın var
  1. ASUS K43SV SSD Replacement, SSD: adım 1, 1 resimden 1.
    • Disconnect the ASUS k43sv laptop from the external power supply before starting.
    • Place the laptop on a flat table with its back facing up.
  2. ASUS K43SV SSD Replacement: adım 2, 1 resimden 1.
    • Slide the latch on the right side of the battery on the back of the laptop to the right to the unlocked position.
  3. ASUS K43SV SSD Replacement: adım 3, 3 resimden 1. ASUS K43SV SSD Replacement: adım 3, 3 resimden 2. ASUS K43SV SSD Replacement: adım 3, 3 resimden 3.
    • With your left hand, slide the latch on the left side of the battery to the left and hold it.
    • With your right hand, slide the battery out of the battery compartment and place the battery away from the laptop.
  4. ASUS K43SV SSD Replacement: adım 4, 2 resimden 1. ASUS K43SV SSD Replacement: adım 4, 2 resimden 2.
    • Remove the two screws on the bottom of the laptop using a Phillips #0 screwdriver.
  5. ASUS K43SV SSD Replacement: adım 5, 3 resimden 1. ASUS K43SV SSD Replacement: adım 5, 3 resimden 2. ASUS K43SV SSD Replacement: adım 5, 3 resimden 3.
    • Slide the hard disk compartment cover towards you with both hands and remove it from the laptop.
  6. ASUS K43SV SSD Replacement: adım 6, 3 resimden 1. ASUS K43SV SSD Replacement: adım 6, 3 resimden 2. ASUS K43SV SSD Replacement: adım 6, 3 resimden 3.
    • Remove the four screws from the hard drive support arm using a Phillips #0 screwdriver.
  7. ASUS K43SV SSD Replacement: adım 7, 3 resimden 1. ASUS K43SV SSD Replacement: adım 7, 3 resimden 2. ASUS K43SV SSD Replacement: adım 7, 3 resimden 3.
    • Lift the plastic sheet on the left side of the hard drive slightly by hand.
    • Remove the hard drive and its support from the hard drive compartment.
  8. ASUS K43SV SSD Replacement: adım 8, 3 resimden 1. ASUS K43SV SSD Replacement: adım 8, 3 resimden 2. ASUS K43SV SSD Replacement: adım 8, 3 resimden 3.
    • Remove the four screws on the side of the hard disk support using a Phillips #0 screwdriver.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Duanrui Liu
279 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 42
Her zaman: 1,027
