Ana içeriğe geç
ASUS K50IJ Screen replacement 15.6" Replacement
Neye ihtiyacın var
  1. ASUS K50IJ Screen replacement 15.6" Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 2, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 2, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 2, 3 resimden 3.
    • Lift the exposed lip and remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS K50IJ Screen replacement 15.6" Replacement: adım 3, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 3, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 3, 3 resimden 3.
    • Press the tabs on the battery and lift them. The battery should come out easily.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS K50IJ Screen replacement 15.6" Replacement, Fan: adım 4, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement, Fan: adım 4, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement, Fan: adım 4, 3 resimden 3.
    • Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS K50IJ Screen replacement 15.6" Replacement: adım 5, 1 resimden 1.
    • Remove the one .5 mm screw located in the top right corner of the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS K50IJ Screen replacement 15.6" Replacement: adım 6, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 6, 2 resimden 2.
    • Remove the bottom panel by sliding it toward the hinges and lifting the back panel up.
    FixBot'a Sor
    Yorum Ekle
  7. ASUS K50IJ Screen replacement 15.6" Replacement: adım 7, 1 resimden 1.
    • Unplug the wire cable attached to the fan by pulling it out .
    FixBot'a Sor
    Yorum Ekle
  8. ASUS K50IJ Screen replacement 15.6" Replacement: adım 8, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 8, 2 resimden 2.
    • Using the PH1 screwdriver, remove the 3 .75mm screws labeled as 1, 2, and 3 on the fan. NOTE these screws have the labels "1", "2", and "3" next to them.
    • Lift the fan up with your fingers.
    FixBot'a Sor
    Yorum Ekle
  9. ASUS K50IJ Screen replacement 15.6" Replacement, Charging Port: adım 9, 1 resimden 1.
    • Using the PH1 screwdriver remove the two .75 mm screws from the hinge side of the laptop.
    FixBot'a Sor
    Yorum Ekle
  10. ASUS K50IJ Screen replacement 15.6" Replacement: adım 10, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 10, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 10, 3 resimden 3.
    • Using the PH1 screwdriver, remove the four .75 mm screws from the copper heat sync. They will be labeled 1-4.
    • Pull the copper heat sync out of the laptop.
    FixBot'a Sor
    Yorum Ekle
  11. ASUS K50IJ Screen replacement 15.6" Replacement: adım 11, 1 resimden 1.
    • Using the PH1 screwdriver, remove four .75 mm screws from the driver, located in the bottom-right corner of the laptop.
    FixBot'a Sor
    Yorum Ekle
  12. ASUS K50IJ Screen replacement 15.6" Replacement: adım 12, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 12, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 12, 3 resimden 3.
    • Pull on the black tab on the driver to slide the driver back, and lift the driver out of the laptop.
    FixBot'a Sor
    Yorum Ekle
  13. ASUS K50IJ Screen replacement 15.6" Replacement: adım 13, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 13, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 13, 3 resimden 3.
    • Using the PH1 screwdriver, remove the five .5 mm screws from the SD card reader, located in the bottom-middle corner of the laptop.
    • Slide the SD card reader away and out.
    FixBot'a Sor
    Yorum Ekle
  14. ASUS K50IJ Screen replacement 15.6" Replacement: adım 14, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 14, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 14, 3 resimden 3.
    • Detach the white and black wires from the Wi-Fi card, located in the central area of the laptop.
    FixBot'a Sor
    Yorum Ekle
  15. ASUS K50IJ Screen replacement 15.6" Replacement: adım 15, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 15, 2 resimden 2.
    • Using the PH 1 screwdriver, remove the two .25 mm screws from the Wi-Fi card.
    FixBot'a Sor
    Yorum Ekle
  16. ASUS K50IJ Screen replacement 15.6" Replacement: adım 16, 1 resimden 1.
    • Slide the Wi-Fi card out of its slot to remove.
    FixBot'a Sor
    Yorum Ekle
  17. ASUS K50IJ Screen replacement 15.6" Replacement: adım 17, 1 resimden 1.
    • Using the PH1mm screwdriver, remove one .5 mm screw from the disk drive, located inthe top-right corner of the laptop.
    FixBot'a Sor
    Yorum Ekle
  18. ASUS K50IJ Screen replacement 15.6" Replacement: adım 18, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 18, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 18, 3 resimden 3.
    • Slide the disc drive out of its slot.
    FixBot'a Sor
    Yorum Ekle
  19. ASUS K50IJ Screen replacement 15.6" Replacement: adım 19, 1 resimden 1.
    • Using the PH 1 screwdriver, remove the two .5 mm screws from the RAM drive.
    FixBot'a Sor
    Yorum Ekle
  20. ASUS K50IJ Screen replacement 15.6" Replacement: adım 20, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 20, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 20, 3 resimden 3.
    • Slide and lift the RAMdrive out of its port.
    FixBot'a Sor
    Yorum Ekle
  21. ASUS K50IJ Screen replacement 15.6" Replacement: adım 21, 1 resimden 1.
    • Using the PH1 screwdriver, remove the .75 mm screw from the plastic housing corner, located in the bottom-right corner of the laptop.
    FixBot'a Sor
    Yorum Ekle
  22. ASUS K50IJ Screen replacement 15.6" Replacement: adım 22, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 22, 2 resimden 2.
    • Unplug the black cable from the central area of the laptop.
    FixBot'a Sor
    Yorum Ekle
  23. ASUS K50IJ Screen replacement 15.6" Replacement: adım 23, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 23, 2 resimden 2.
    • Unplug the wire cable in the central area of the laptop.
    FixBot'a Sor
    Yorum Ekle
  24. ASUS K50IJ Screen replacement 15.6" Replacement: adım 24, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 24, 2 resimden 2.
    • Unplug the wire and black cables on the motherboard, located in the upper-left corner of the laptop.
    FixBot'a Sor
    Yorum Ekle
  25. ASUS K50IJ Screen replacement 15.6" Replacement: adım 25, 1 resimden 1.
    • Using the PH1 screwdriver, unscrew the two .75 mm screws from the top-left corner of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  26. ASUS K50IJ Screen replacement 15.6" Replacement: adım 26, 1 resimden 1.
    • Using the PH 1 screwdriver, remove the .75 cm screw from the top-middle section of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  27. ASUS K50IJ Screen replacement 15.6" Replacement: adım 27, 1 resimden 1.
    • Using the PH1 screwdriver, remove the .75 mm screw from the top-middle corner of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  28. ASUS K50IJ Screen replacement 15.6" Replacement: adım 28, 1 resimden 1.
    • Using the PH1 screwdriver, remove the three .75 mm screws from the bottom corner of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  29. ASUS K50IJ Screen replacement 15.6" Replacement: adım 29, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 29, 2 resimden 2.
    • There is a ribbon cable connected to the back of the motherboard. Be careful not to break the ribbon cable.
    • Slide the motherboard to the right and lift it up, but do not pull it completely out.
    FixBot'a Sor
    Yorum Ekle
  30. ASUS K50IJ Screen replacement 15.6" Replacement: adım 30, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 30, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 30, 3 resimden 3.
    • Gently unplug the ribbon cable from the underside of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  31. ASUS K50IJ Screen replacement 15.6" Replacement: adım 31, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 31, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 31, 3 resimden 3.
    • The ribbon cable that was plugged into the motherboard is attached to the keyboard. Be sure not to damage it.
    • Use the metal spudger or opening tool across the top edge of the keyboard to pop it out.
    FixBot'a Sor
    Yorum Ekle
  32. ASUS K50IJ Screen replacement 15.6" Replacement: adım 32, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 32, 2 resimden 2.
    • Use the metal spudger or opening tool to pop out the plastic hinge covers.
    FixBot'a Sor
    Yorum Ekle
  33. ASUS K50IJ Screen replacement 15.6" Replacement: adım 33, 1 resimden 1.
    • Use the PH1 screwdriver to remove the .75 mm screws from the hinges. Each hinge has one screw.
    FixBot'a Sor
    Yorum Ekle
  34. ASUS K50IJ Screen replacement 15.6" Replacement: adım 34, 1 resimden 1.
    • Be careful not to damage the cables that are attached to the screen frame. Be sure to pull them through the laptop carefully.
    • The screen should separate from the rest of the laptop.
    FixBot'a Sor
    Yorum Ekle
  35. ASUS K50IJ Screen replacement 15.6" Replacement: adım 35, 1 resimden 1.
    • Using the PH1 screwdriver, remove the .75 mm screw from the bottom-middle section was previously covering.
    FixBot'a Sor
    Yorum Ekle
  36. ASUS K50IJ Screen replacement 15.6" Replacement: adım 36, 1 resimden 1.
    • Using the PH 1 screwdriver, remove the .75 cm screw from the bottom-middle section where the keyboard was previously covering.
    FixBot'a Sor
    Yorum Ekle
  37. ASUS K50IJ Screen replacement 15.6" Replacement: adım 37, 1 resimden 1.
    • Lift the front cover off of the laptop.
    FixBot'a Sor
    Yorum Ekle
  38. ASUS K50IJ Screen replacement 15.6" Replacement: adım 38, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 38, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 38, 3 resimden 3.
    • Flip the laptop back over. The charging port will be located in the top-right corner.
    FixBot'a Sor
    Yorum Ekle
  39. ASUS K50IJ Screen replacement 15.6" Replacement, Screen replacement 15.6": adım 39, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement, Screen replacement 15.6": adım 39, 2 resimden 2.
    • Using a metal spudger, pop off the six rubber screw covers.
    FixBot'a Sor
    Yorum Ekle
  40. ASUS K50IJ Screen replacement 15.6" Replacement: adım 40, 2 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 40, 2 resimden 2.
    • Using the PH1mm screwdriver, remove the six .75 mm screws from the front of the screen frame.
    FixBot'a Sor
    Yorum Ekle
  41. ASUS K50IJ Screen replacement 15.6" Replacement: adım 41, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 41, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 41, 3 resimden 3.
    • Use the plastic opening tool or spudger along the edge of the frame, to pry off the frame.
    FixBot'a Sor
    Yorum Ekle
  42. ASUS K50IJ Screen replacement 15.6" Replacement: adım 42, 3 resimden 1. ASUS K50IJ Screen replacement 15.6" Replacement: adım 42, 3 resimden 2. ASUS K50IJ Screen replacement 15.6" Replacement: adım 42, 3 resimden 3.
    • Using the PH1 screwdriver, remove the four bottom .75 mm screws from the screen frame.
    FixBot'a Sor
    Yorum Ekle
  43. ASUS K50IJ Screen replacement 15.6" Replacement: adım 43, 1 resimden 1.
    • Using the PH1 screwdriver, remove the two .75 cm screws from the top of the screen frame.
    FixBot'a Sor
    Yorum Ekle
  44. ASUS K50IJ Screen replacement 15.6" Replacement: adım 44, 1 resimden 1.
    • Lift the bracket off the top of the screen frame.
    FixBot'a Sor
    Yorum Ekle
  45. ASUS K50IJ Screen replacement 15.6" Replacement: adım 45, 1 resimden 1.
    • Lift the screen should out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
Very well done. Thank You
Rc wells - Yanıt Paylaş
Thank you for your time!
tatiana.morais.89 - Yanıt Paylaş
Now, I don´t know how to connect the cables to the motherboard because they are too short.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 1,608
