Ana içeriğe geç
ASUS K53E-BBR1 Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS K53E-BBR1 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 Hard Drive Replacement: adım 3, 3 resimden 1. ASUS K53E-BBR1 Hard Drive Replacement: adım 3, 3 resimden 2. ASUS K53E-BBR1 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. ASUS K53E-BBR1 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Remove the two 4mm Phillips #0 screws on either side of the laptop.
  5. ASUS K53E-BBR1 Hard Drive Replacement: adım 5, 2 resimden 1. ASUS K53E-BBR1 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Slide the back panel towards you until it stops.
    • Lift the panel up out of the laptop casing.
  6. ASUS K53E-BBR1 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Remove the four 3mm Phillips #0 screws holding the hard drive in place.
  7. ASUS K53E-BBR1 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Disconnect the hard drive from the laptop by sliding it towards the outside edge.
  8. ASUS K53E-BBR1 Hard Drive Replacement: adım 8, 2 resimden 1. ASUS K53E-BBR1 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Grab hold of the black cloth tab and pull the hard drive out from the laptop.
Sonuç
Matthew Merlo
267 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Peak Spring 2019 UMass Dartmouth, Team S6-G4, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 269
