Ana içeriğe geç
ASUS K53E-BBR1 Keyboard Replacement
Neye ihtiyacın var
    1. ASUS K53E-BBR1 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
      • Lift the monitor up so that the keyboard is visible.
      • You will notice five spots on the top of the keyboard where the iFixit opening tool should be placed.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS K53E-BBR1 Keyboard Replacement: adım 2, 3 resimden 1. ASUS K53E-BBR1 Keyboard Replacement: adım 2, 3 resimden 2. ASUS K53E-BBR1 Keyboard Replacement: adım 2, 3 resimden 3.
      • Use the iFixit opening tool on each of the designated spots to pry the keyboard apart from the palm rest.
      • You will hear a light "pop" sound each time you pry the keyboard.
      • Once the keyboard is loose, do not pull keyboard far (more than 3 inches) apart from the from the palm rest. There is a "bus" connector attached to the bottom.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS K53E-BBR1 Keyboard Replacement: adım 3, 1 resimden 1.
      • Carefully disconnect the "bus" connector from the laptop. Press on it with your thumb/index finger and slide it right along the surface of the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Paulo Fortes
147 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Peak Spring 2019 UMass Dartmouth, Team S6-G4, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G4
3 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 763
