Ana içeriğe geç
ASUS K53E-BBR1 RAM Replacement
Neye ihtiyacın var
  1. ASUS K53E-BBR1 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so you can see the battery.
  2. ASUS K53E-BBR1 RAM Replacement: adım 2, 1 resimden 1.
    • Slide the lock on the right side of the battery to the right. If done correctly the slider will stay in place and there will be a red indicator.
  3. ASUS K53E-BBR1 RAM Replacement: adım 3, 3 resimden 1. ASUS K53E-BBR1 RAM Replacement: adım 3, 3 resimden 2. ASUS K53E-BBR1 RAM Replacement: adım 3, 3 resimden 3.
    • Slide the other sliding lock on the left side of the battery to the left, and with your other hand slide the battery out from the laptop.
  4. ASUS K53E-BBR1 RAM Replacement, RAM: adım 4, 2 resimden 1. ASUS K53E-BBR1 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Remove the two 4mm Phillips #0 screws located on the opposite ends of the laptop.
  5. ASUS K53E-BBR1 RAM Replacement: adım 5, 2 resimden 1. ASUS K53E-BBR1 RAM Replacement: adım 5, 2 resimden 2.
    • Slide the back panel backwards until it stops.
    • You can now lift the panel up and out of the laptop casing.
  6. ASUS K53E-BBR1 RAM Replacement: adım 6, 3 resimden 1. ASUS K53E-BBR1 RAM Replacement: adım 6, 3 resimden 2. ASUS K53E-BBR1 RAM Replacement: adım 6, 3 resimden 3.
    • The RAM is now visible.
    • Remove the RAM by pressing out on both tabs visible on each side of the RAM.
    • To work the tabs, take your finger tips and press outwards from the indents on the RAM.
  7. ASUS K53E-BBR1 RAM Replacement: adım 7, 2 resimden 1. ASUS K53E-BBR1 RAM Replacement: adım 7, 2 resimden 2.
    • The RAM is now angled up and you can remove the RAM by pulling it out in the direction it is facing.
    • Gently Pull the RAM out of its connector without pushing down or pulling up.
  8. ASUS K53E-BBR1 RAM Replacement: adım 8, 3 resimden 1. ASUS K53E-BBR1 RAM Replacement: adım 8, 3 resimden 2. ASUS K53E-BBR1 RAM Replacement: adım 8, 3 resimden 3.
    • Repeat the previous two steps for the second stick of RAM.
Sonuç
William Colangelo
121 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S6-G4, Peak Spring 2019 UMass Dartmouth, Team S6-G4, Peak Spring 2019 üyesi
UMASSD-PEAK-S19S6G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 210
