Giriş
Use this guide to replace the front and rear cameras of your ASUS MeMo Pad FHD10 if they are not working or malfunctioning. This guide could also be used to adjust or clean the cameras in case of blurry camera's display or dislocation.
Neye ihtiyacın var
Unplug the charger and remove any memory card you may have in the device.
Wedge the plastic opening tool between the front and back cover on every side.
Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
Once disconnected, remove the back cover from the device screen.
Identify the location of front and rear cameras on the motherboard.
The front and rear cameras can be removed by pulling them out gently using hands.
