Ana içeriğe geç
ASUS MeMo Pad FHD10 Headphone Jack Replacement
Neye ihtiyacın var
  1. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Battery: adım 1, 2 resimden 1. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure that the device is turned off as a precaution.
    • Unplug the charger and remove any memory card you may have in the device.
    • Wedge the plastic opening tool between the front and back cover on every side.
    • Slide the plastic opening tool back and forth to make sure that the back cover is disconnected.
    • Once disconnected, remove the back cover from the device screen.
  2. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 2, 2 resimden 1. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 2, 2 resimden 2.
    • Remove the protective copper sticker and all tape fixed on the device.
    • Using tweezers, remove the ribbon cable from their connections attached to the motherboard.
    • While using the tweezers, make sure to use minimum force and precision to avoid damaging any components.
  3. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 3, 2 resimden 1. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 3, 2 resimden 2.
    • Remove the four 2 mm Phillips #00 screws holding the battery tray in place.
  4. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 4, 3 resimden 1. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 4, 3 resimden 2. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 4, 3 resimden 3.
    • Locate the battery cable attached to the motherboard. Using the same technique used on the ribbons, do the same with the battery.
    • Remove the battery from the device. Once removed, use the plastic tool to separate the metal frame from the battery.
    • When separating the metal frame, be sure to hold on in the center as the battery is two separate cells.
  5. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Speakers: adım 5, 1 resimden 1.
    • Remove three screws using a Phillips #00 screwdriver.
  6. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 6, 1 resimden 1.
    • The two speakers are located on opposite sides of the device. Both are long black pieces with connections to the motherboard.
    • Unplug the speaker cables from their connections on the motherboard gently by using tweezers.
  7. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 7, 3 resimden 1. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 7, 3 resimden 2. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 7, 3 resimden 3.
    • Gently use your hands to remove the speakers.
  8. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Motherboard: adım 8, 1 resimden 1.
    • Remove the five screws using a Phillips #00 screwdriver.
  9. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 9, 3 resimden 1. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 9, 3 resimden 2. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 9, 3 resimden 3.
    • Carefully disconnect the cord that connects the on/off button to the motherboard
    • Peel back the electrical tape holding the connections of the motherboard down to the frame of the device.
  10. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 10, 1 resimden 1.
    • Use your hands to remove the motherboard from the device.
  11. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Headphone Jack: adım 11, 2 resimden 1. ASUS MeMo Pad FHD10 Headphone Jack Replacement, Headphone Jack: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    Satın Al
    • Using a soldering gun, desolder the headphone jack from the motherboard at each connection to the motherboard.
    • If you have never used a soldering gun before, check out iFixit's guide for soldering and desoldering.
  12. ASUS MeMo Pad FHD10 Headphone Jack Replacement: adım 12, 1 resimden 1.
    • Gently, disconnect the headphone jack.
    • Allow the soldering to cool off before disconnecting.
Sonuç
Dmitry
391 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-5, Blackwell Winter 2015 USF Tampa, Team 9-5, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S9G5
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,412
