Ana içeriğe geç
ASUS N550JK-DS71T Laptop Battery Replacement
Neye ihtiyacın var
  1. ASUS N550JK-DS71T Laptop Battery Replacement, Back Case: adım 1, 2 resimden 1. ASUS N550JK-DS71T Laptop Battery Replacement, Back Case: adım 1, 2 resimden 2.
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop Battery Replacement: adım 2, 2 resimden 1. ASUS N550JK-DS71T Laptop Battery Replacement: adım 2, 2 resimden 2.
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop Battery Replacement, Battery: adım 3, 2 resimden 1. ASUS N550JK-DS71T Laptop Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the three 4mm JIS #0 screws from the battery.
  4. ASUS N550JK-DS71T Laptop Battery Replacement: adım 4, 2 resimden 1. ASUS N550JK-DS71T Laptop Battery Replacement: adım 4, 2 resimden 2.
    • Using both hands, lift the battery vertically out of the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Steven Hahn
884 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G1, Passmore Spring 2018 USF Tampa, Team S5-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 22
Her zaman: 2,784
