Ana içeriğe geç
ASUS N550JK-DS71T Laptop Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS N550JK-DS71T Laptop Hard Drive Replacement, Back Case: adım 1, 2 resimden 1. ASUS N550JK-DS71T Laptop Hard Drive Replacement, Back Case: adım 1, 2 resimden 2.
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop Hard Drive Replacement: adım 2, 2 resimden 1. ASUS N550JK-DS71T Laptop Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. ASUS N550JK-DS71T Laptop Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Remove two 4mm black Phillips #1 screws from CD/DVD bracket.
    • Remove the single 4mm silver Phillips #1 screw from the bottom of the CD/DVD bracket.
    • Remove the CD/DVD bracket.
  4. ASUS N550JK-DS71T Laptop Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the four 4mm silver Phillips #1 screws that are holding the hard drive in place.
  5. ASUS N550JK-DS71T Laptop Hard Drive Replacement: adım 5, 2 resimden 1. ASUS N550JK-DS71T Laptop Hard Drive Replacement: adım 5, 2 resimden 2.
    • Lift up and remove the hard drive from the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Steven Hahn
884 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G1, Passmore Spring 2018 USF Tampa, Team S5-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 2,538
