Ana içeriğe geç
ASUS N550JK-DS71T Laptop RAM stick Replacement
Neye ihtiyacın var
  1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: adım 1, 2 resimden 1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Back Case: adım 1, 2 resimden 2.
    • Turn the laptop off and unplug all cables.
    • Flip over so the bottom is facing you.
    • Remove the ten 3mm Torx T5 screws from the bottom cover.
  2. ASUS N550JK-DS71T Laptop RAM stick Replacement: adım 2, 2 resimden 1. ASUS N550JK-DS71T Laptop RAM stick Replacement: adım 2, 2 resimden 2.
    • Use a spudger to wedge between the laptop and bottom cover—lift upwards to pry open.
    • Run the spudger along the perimeter of the bottom cover to remove.
  3. ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: adım 3, 2 resimden 1. ASUS N550JK-DS71T Laptop RAM stick Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the three 4mm JIS #0 screws from the battery.
  4. ASUS N550JK-DS71T Laptop RAM stick Replacement: adım 4, 2 resimden 1. ASUS N550JK-DS71T Laptop RAM stick Replacement: adım 4, 2 resimden 2.
    • Using both hands, lift the battery vertically out of the device.
  5. ASUS N550JK-DS71T Laptop RAM stick Replacement, RAM Stick: adım 5, 1 resimden 1.
    • Put on anti-static wristband and attach clip-end to any metal screw insert.
    • The wristband is recommended when working closely with circuit boards due to potential static discharge.
  6. ASUS N550JK-DS71T Laptop RAM stick Replacement: adım 6, 3 resimden 1. ASUS N550JK-DS71T Laptop RAM stick Replacement: adım 6, 3 resimden 2. ASUS N550JK-DS71T Laptop RAM stick Replacement: adım 6, 3 resimden 3.
    • The RAM will be secured by two metal clips surrounded by white plastic.
    • Spread the metal clips and the RAM stick will pop up. Then gently remove the RAM stick.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Steven Hahn
875 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G1, Passmore Spring 2018 USF Tampa, Team S5-G1, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,141
