Giriş
This guide will show how to remove and replace the RAM on your Asus N550JK-DS71T laptop.
Neye ihtiyacın var
Turn the laptop off and unplug all cables.
Flip over so the bottom is facing you.
Remove the ten 3mm Torx T5 screws from the bottom cover.
Put on anti-static wristband and attach clip-end to any metal screw insert.
Bir başkası bu kılavuzu tamamladı.
