Ana içeriğe geç
ASUS PadFone X Battery Replacement
Neye ihtiyacın var
  1. ASUS PadFone X Battery Replacement, Remove the back panel.: adım 1, 2 resimden 1. ASUS PadFone X Battery Replacement, Remove the back panel.: adım 1, 2 resimden 2.
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Battery Replacement, Remove the screws.: adım 2, 2 resimden 1. ASUS PadFone X Battery Replacement, Remove the screws.: adım 2, 2 resimden 2.
    • Remove the 13 - 3.6 mm screws using the Torx T5 bit in the screwdriver.
  3. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: adım 3, 2 resimden 1. ASUS PadFone X Battery Replacement, Remove the Mid-Frame: adım 3, 2 resimden 2.
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Battery Replacement, Remove the Battery Connector: adım 4, 2 resimden 1. ASUS PadFone X Battery Replacement, Remove the Battery Connector: adım 4, 2 resimden 2.
    • Using the blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Battery Replacement, Remove the battery.: adım 5, 2 resimden 1. ASUS PadFone X Battery Replacement, Remove the battery.: adım 5, 2 resimden 2.
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
John Kue
379 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 5,184
