Ana içeriğe geç
ASUS PadFone X Front Facing Camera Replacement
Neye ihtiyacın var
  1. ASUS PadFone X Front Facing Camera  Replacement, Motherboard: adım 1, 2 resimden 1. ASUS PadFone X Front Facing Camera  Replacement, Motherboard: adım 1, 2 resimden 2.
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS PadFone X Front Facing Camera  Replacement: adım 2, 2 resimden 1. ASUS PadFone X Front Facing Camera  Replacement: adım 2, 2 resimden 2.
    • Remove the thirteen 3.6 mm screws using the Torx T5 bit in the screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS PadFone X Front Facing Camera  Replacement: adım 3, 2 resimden 1. ASUS PadFone X Front Facing Camera  Replacement: adım 3, 2 resimden 2.
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS PadFone X Front Facing Camera  Replacement: adım 4, 1 resimden 1.
    • Using the plastic blue plastic opening tool, gently disconnect the battery cable from the motherboard.
    • Applying too much force will damage the connector.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS PadFone X Front Facing Camera  Replacement: adım 5, 2 resimden 1. ASUS PadFone X Front Facing Camera  Replacement: adım 5, 2 resimden 2.
    • Use the blue plastic opening tool to pry the battery pack from the phone. Pry along edge away from the motherboard as this might damage the motherboard.
    • The battery pack is held on by double sided tape, you will have to apply some force when prying out the battery.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS PadFone X Front Facing Camera  Replacement: adım 6, 1 resimden 1.
    • Using a spudger, pry the vibration motor connector from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. ASUS PadFone X Front Facing Camera  Replacement: adım 7, 1 resimden 1.
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force will damage the conector
    FixBot'a Sor
    Yorum Ekle
  8. ASUS PadFone X Front Facing Camera  Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
    FixBot'a Sor
    Yorum Ekle
  9. ASUS PadFone X Front Facing Camera  Replacement: adım 9, 2 resimden 1. ASUS PadFone X Front Facing Camera  Replacement: adım 9, 2 resimden 2.
    • Insert the tip of the flat head screwdriver between the panel and the metal clip then gently push down until the clip is slightly bent away from the panel.
    • Do this for all the clips holding the panel down.
    • After all clips are bent away, remove the panel.
    FixBot'a Sor
    Yorum Ekle
  10. ASUS PadFone X Front Facing Camera  Replacement: adım 10, 2 resimden 1. ASUS PadFone X Front Facing Camera  Replacement: adım 10, 2 resimden 2.
    • Disconnect the first connector by prying it upward using the blue plastic opening tool.
    • Disconnect the second connector by first lifting the lock then pulling the connector outward.
    FixBot'a Sor
    Yorum Ekle
  11. ASUS PadFone X Front Facing Camera  Replacement: adım 11, 3 resimden 1. ASUS PadFone X Front Facing Camera  Replacement: adım 11, 3 resimden 2. ASUS PadFone X Front Facing Camera  Replacement: adım 11, 3 resimden 3.
    • Insert the tip of the blue plastic opening tool under the motherboard and gently pry upward.
    • Work your way around until the motherboard is free.
    FixBot'a Sor
    Yorum Ekle
  12. ASUS PadFone X Front Facing Camera  Replacement: adım 12, 1 resimden 1.
    • Flip the motherboard over and locate the front facing camera.
    • Using the tweezers gently remove the black locking mechanism.
    • The black locking mechanism is very fragile and extreme care should be exercised during removal.
    FixBot'a Sor
    Yorum Ekle
  13. ASUS PadFone X Front Facing Camera  Replacement: adım 13, 2 resimden 1. ASUS PadFone X Front Facing Camera  Replacement: adım 13, 2 resimden 2.
    • Use the tweezers to gently pull on the connector to remove the camera.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Keith Cooper
122 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Spring 2017 IUPUI, Team 2-1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S2G1
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 615
