Ana içeriğe geç
ASUS PadFone X Rear Case Replacement
Neye ihtiyacın var
  1. ASUS PadFone X Rear Case Replacement, Remove the back panel.: adım 1, 2 resimden 1. ASUS PadFone X Rear Case Replacement, Remove the back panel.: adım 1, 2 resimden 2.
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS PadFone X Rear Case Replacement, Antenna replacement: adım 2, 1 resimden 1.
    • Replace the back cover with the new one; the antenna is integrated with the back panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
John Kue
379 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 1,249
