Ana içeriğe geç
ASUS PadFone X Rear Facing Camera Replacement
Neye ihtiyacın var
  1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: adım 1, 2 resimden 1. ASUS PadFone X Rear Facing Camera Replacement, Remove the back panel: adım 1, 2 resimden 2.
    • Using the blue plastic opening tool, insert the tip into the crease between the back cover and the phone and pry it upward.
    • Work your way around the phone until the entire back cover is loose.
  2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: adım 2, 3 resimden 1. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: adım 2, 3 resimden 2. ASUS PadFone X Rear Facing Camera Replacement, Remove the screws.: adım 2, 3 resimden 3.
    • Remove the thirteen 3.6 mm screws using the torx T5 bit in the screwdriver.
  3. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: adım 3, 2 resimden 1. ASUS PadFone X Rear Facing Camera Replacement, Remove the Mid-Frame.: adım 3, 2 resimden 2.
    • Using the blue plastic opening tool, insert the tip into the crease between the mid-frame and the phone and pry it upwards.
    • Work your way around the phone until the entire back cover is loose and remove the mid-frame.
  4. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera connector.: adım 4, 1 resimden 1.
    • Use the blue plastic opening tool to gently pry the camera connector up from its socket on the motherboard.
    • Applying too much force may damage the connector.
  5. ASUS PadFone X Rear Facing Camera Replacement, Remove the camera.: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the tweezers, remove the rear camera from the Padfone X.
    • The camera is lightly glued to the motherboard. You may need to use a plastic opening tool to loosen the adhesive under the camera.
  6. ASUS PadFone X Rear Facing Camera Replacement, Replacing the camera.: adım 6, 1 resimden 1.
    • Once the camera has been pulled out, replace the old camera with a new camera.
Sonuç
nestor
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 8-4, Leahy Fall 2014 USF Tampa, Team 8-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 630
