Ana içeriğe geç
ASUS PadFone X Speaker Replacement
Neye ihtiyacın var
  1. ASUS PadFone X Speaker Replacement, Speaker: adım 1, 2 resimden 1. ASUS PadFone X Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Pry off the back cover with the blue plastic opening tool. This may require a bit of force.
  2. ASUS PadFone X Speaker Replacement: adım 2, 2 resimden 1. ASUS PadFone X Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the thirteen 3.6mm screws using the T5 Torx Screwdriver.
  3. ASUS PadFone X Speaker Replacement: adım 3, 1 resimden 1.
    • Once the screws are removed, the mid-frame can be lifted off of the phone. The speaker is on the mid-frame.
  4. ASUS PadFone X Speaker Replacement: adım 4, 2 resimden 1. ASUS PadFone X Speaker Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to pry out the speaker. It should come out fairly easily.
    • Pick the speaker up and out of the mid-frame.
Sonuç
William Beale
104 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Spring 2017 IUPUI, Team 2-1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S2G1
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 242
