Ana içeriğe geç
ASUS PadFone X Station Battery Replacement
Neye ihtiyacın var
  1. ASUS PadFone X Station Battery Replacement, Back Cover: adım 1, 2 resimden 1. ASUS PadFone X Station Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Battery Replacement, Finding the Battery: adım 2, 1 resimden 1.
    • Locate 4600mAh Battery
  3. ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: adım 3, 2 resimden 1. ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate (+) and (-) battery terminals
    • Trace black, white, red, and yellow wires to connection on motherboard
    • Remove protective plastic cover with tweezers
  4. ASUS PadFone X Station Battery Replacement, Disconnecting the Ribbon: adım 4, 1 resimden 1.
    • Disconnect connect ribbon by gently pulling with fingers
    • Ensure the ribbon does not touch metallic items (This may short out battery and cause an explosion)
  5. ASUS PadFone X Station Battery Replacement, Removing the Screws: adım 5, 2 resimden 1. ASUS PadFone X Station Battery Replacement, Removing the Screws: adım 5, 2 resimden 2.
    • Remove (4) screws
  6. ASUS PadFone X Station Battery Replacement, Taking out the Battery: adım 6, 3 resimden 1. ASUS PadFone X Station Battery Replacement, Taking out the Battery: adım 6, 3 resimden 2. ASUS PadFone X Station Battery Replacement, Taking out the Battery: adım 6, 3 resimden 3.
    • Gently pry battery off glued surface
    • Use of a plastic opening tools and a spudger are necessary
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Paul Wagner
545 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S7G4
4 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
where can i find a battery for that station pls?
francidorio - Yanıt
Hello dear. Thanks for the tutorial on how to change the Padfone X tablet battery.
I have the Padfone x station without the cell phone because unfortunately my students have stolen it from me in the classroom while attending a mother (in Cordoba, Argentina).
I would like to know, then, if I could adapt an Asus cell phone model by changing the slot in the cell phone and / or in the tablet station in the back where both devices are embedded, so, what kind of spare parts should buy, and with which name to ask.
Since a thousand and one thanks. Best regards from Cordoba, Argentina.
Clara.
calejanmm - Yanıt
The proper battery for this unit is C11P1323.
acg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 3,708
