Ana içeriğe geç
ASUS PadFone X Station Docking Connector Replacement
Neye ihtiyacın var
  1. ASUS PadFone X Station Docking Connector Replacement, Back Cover: adım 1, 2 resimden 1. ASUS PadFone X Station Docking Connector Replacement, Back Cover: adım 1, 2 resimden 2.
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Docking Connector Replacement, USB connector: adım 2, 2 resimden 1. ASUS PadFone X Station Docking Connector Replacement, USB connector: adım 2, 2 resimden 2.
    • Locate the CON101
    • The white sticker indicates water exposure. White=none, Red=Exposure
  3. ASUS PadFone X Station Docking Connector Replacement, Remove two Phillips screws: adım 3, 1 resimden 1.
    • Remove two Phillips screws
  4. ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: adım 4, 2 resimden 1. ASUS PadFone X Station Docking Connector Replacement, Locate P92L on CON1504: adım 4, 2 resimden 2.
    • Locate P92L on CON1504
    • Gently peel back and remove plastic tape
  5. ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: adım 5, 3 resimden 1. ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: adım 5, 3 resimden 2. ASUS PadFone X Station Docking Connector Replacement, Removal of P92L: adım 5, 3 resimden 3.
    • Gently Pull P92L With Fingers From CON1504
  6. ASUS PadFone X Station Docking Connector Replacement, Identification of Antenna Wires: adım 6, 1 resimden 1.
    • These are the antenna wires.
    • Trace these wires to locate the two antennas.
  7. ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: adım 7, 2 resimden 1. ASUS PadFone X Station Docking Connector Replacement, Desolder the two antenna wires: adım 7, 2 resimden 2.
    • Locate the two antennas
    • Desolder the two antenna wires
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel
338 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S7G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 1,425
