Ana içeriğe geç
ASUS PadFone X Station USB Charging Port Replacement
Neye ihtiyacın var
  1. ASUS PadFone X Station USB Charging Port Replacement, Back Cover: adım 1, 2 resimden 1. ASUS PadFone X Station USB Charging Port Replacement, Back Cover: adım 1, 2 resimden 2.
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: adım 2, 2 resimden 1. ASUS PadFone X Station USB Charging Port Replacement, Check USB Charging Port for water damage: adım 2, 2 resimden 2.
    • Locate CON2002
    • Check water indicator on USB Charging Port
    • A white indicator means there is no water damage. A red indicator means there was water damage.
  3. ASUS PadFone X Station USB Charging Port Replacement, Removing Charging Port: adım 3, 1 resimden 1.
    • Locate and remove three Phillips screws
  4. ASUS PadFone X Station USB Charging Port Replacement, Disconnect E893821: adım 4, 1 resimden 1.
    • Use a pair of tweezers to disconnect E893821
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Daniel
338 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S7G4
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Does anyone have any idea where a replacement USB port can be found. Mine isnt water damaged but rather one of the pins broke off and its hanging out of the cable. Now the phone will not charge.
rich - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 2,690
