Ana içeriğe geç
ASUS Padfone X mini Station Battery Replacement
Neye ihtiyacın var
  1. ASUS Padfone X mini Station Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Battery Replacement: adım 2, 2 resimden 1. ASUS Padfone X mini Station Battery Replacement: adım 2, 2 resimden 2.
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Battery Replacement: adım 3, 3 resimden 1. ASUS Padfone X mini Station Battery Replacement: adım 3, 3 resimden 2. ASUS Padfone X mini Station Battery Replacement: adım 3, 3 resimden 3.
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
Sonuç
Alexzander Pastore
389 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Peak Fall 2018 UMass Dartmouth, Team S2-G7, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G7
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 494
