Ana içeriğe geç
ASUS Padfone X mini Station Front Camera Replacement
Neye ihtiyacın var
  1. ASUS Padfone X mini Station Front Camera Replacement, Front Camera Lens: adım 1, 1 resimden 1.
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Front Camera Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  3. ASUS Padfone X mini Station Front Camera Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove cover sticker on the dock station.
  4. ASUS Padfone X mini Station Front Camera Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the six 0.6mm screws that secure the dock station case to the motherboard.
  5. ASUS Padfone X mini Station Front Camera Replacement: adım 5, 1 resimden 1.
    • Flip the device upwards.
    • Gently push the right side of motherboard down away from the dock station.
    • Do not push the motherboard so hard as it is still attached to a connector. Excessive force applied might cause external damage to it.
  6. ASUS Padfone X mini Station Front Camera Replacement: adım 6, 2 resimden 1. ASUS Padfone X mini Station Front Camera Replacement: adım 6, 2 resimden 2.
    • Use tweezers to detach the camera from the motherboard.
Sonuç
Ekip
UMass Dartmouth, Team S2-G7, Peak Fall 2018 UMass Dartmouth, Team S2-G7, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G7
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
I can not get my back off the device at the top of it it doesn't want to complete separate.
Jannell A McDonald - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 169
