Ana içeriğe geç
ASUS Padfone X mini Station Speaker Replacement
Neye ihtiyacın var
  1. ASUS Padfone X mini Station Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Speaker Replacement: adım 2, 2 resimden 1. ASUS Padfone X mini Station Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Speaker Replacement: adım 3, 3 resimden 1. ASUS Padfone X mini Station Speaker Replacement: adım 3, 3 resimden 2. ASUS Padfone X mini Station Speaker Replacement: adım 3, 3 resimden 3.
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
  4. ASUS Padfone X mini Station Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  5. ASUS Padfone X mini Station Speaker Replacement: adım 5, 3 resimden 1. ASUS Padfone X mini Station Speaker Replacement: adım 5, 3 resimden 2. ASUS Padfone X mini Station Speaker Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove the three pieces of tape that are covering the metal.
    • Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
  6. ASUS Padfone X mini Station Speaker Replacement: adım 6, 2 resimden 1. ASUS Padfone X mini Station Speaker Replacement: adım 6, 2 resimden 2.
    • Use tweezers to detach the connecter from the motherboard.
Sonuç
Alexzander Pastore
389 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G7, Peak Fall 2018 UMass Dartmouth, Team S2-G7, Peak Fall 2018 üyesi
UMASSD-PEAK-F18S2G7
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 163
