Giriş
This guide will be helpful for repairing the speaker if the troubleshooting page recommends that you replace it. This is a necessary step when you have determined no other way to repair your current speaker.
Neye ihtiyacın var
Insert the plastic opening tool between the edge of the screen and the back cover.
Gently pry them apart. Use hands to pull them apart if necessary.
Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
