Giriş
We will replace the hard drive in this guide. The only necessary tools are a screwdriver and a spudger/plastic opening tool.
Neye ihtiyacın var
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
Remove the four 5.0 mm Phillips #1 screws on the outer casing of the hard drive.
2 farklı kişi bu kılavuzu tamamladı.
