Ana içeriğe geç
ASUS Q302L Display Replacement
Neye ihtiyacın var
  1. ASUS Q302L Display Replacement, Back Case: adım 1, 1 resimden 1.
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Display Replacement: adım 2, 3 resimden 1. ASUS Q302L Display Replacement: adım 2, 3 resimden 2. ASUS Q302L Display Replacement: adım 2, 3 resimden 3.
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Display Replacement: adım 3, 1 resimden 1.
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Display Replacement, Battery: adım 4, 1 resimden 1.
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Display Replacement: adım 5, 3 resimden 1. ASUS Q302L Display Replacement: adım 5, 3 resimden 2. ASUS Q302L Display Replacement: adım 5, 3 resimden 3.
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Display Replacement: adım 6, 2 resimden 1. ASUS Q302L Display Replacement: adım 6, 2 resimden 2.
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Display Replacement, Display: adım 7, 2 resimden 1. ASUS Q302L Display Replacement, Display: adım 7, 2 resimden 2.
    • Use a Phillips #00 screw driver to remove the five 10mm screws at the hinges.
  8. ASUS Q302L Display Replacement: adım 8, 3 resimden 1. ASUS Q302L Display Replacement: adım 8, 3 resimden 2. ASUS Q302L Display Replacement: adım 8, 3 resimden 3.
    • Peel back the tape and remove the two connectors.
  9. ASUS Q302L Display Replacement: adım 9, 2 resimden 1. ASUS Q302L Display Replacement: adım 9, 2 resimden 2.
    • Pull up on the black tab to remove the connector that connects to the motherboard.
    • Unplug the hard drive cable from the hard drive.
    • Carefully remove the cables from the track that they run through.
  10. ASUS Q302L Display Replacement: adım 10, 2 resimden 1. ASUS Q302L Display Replacement: adım 10, 2 resimden 2.
    • Carefully remove the display from the rest of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Lozier
290 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Harley Spring 2019 IUPUI, Team S2-G4, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,141
