Ana içeriğe geç
ASUS Q302L Display Replacement
Neye ihtiyacın var
    1. ASUS Q302L Display Replacement, Back Case: adım 1, 1 resimden 1.
      • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
      • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Q302L Display Replacement: adım 2, 3 resimden 1. ASUS Q302L Display Replacement: adım 2, 3 resimden 2. ASUS Q302L Display Replacement: adım 2, 3 resimden 3.
      • Wedge a plastic opening tool under the rear case near the hinge.
      • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Q302L Display Replacement: adım 3, 1 resimden 1.
      • Once the cover is free from all the clips, remove the cover from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS Q302L Display Replacement, Battery: adım 4, 1 resimden 1.
      • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Q302L Display Replacement: adım 5, 3 resimden 1. ASUS Q302L Display Replacement: adım 5, 3 resimden 2. ASUS Q302L Display Replacement: adım 5, 3 resimden 3.
      • Gently wedge a plastic opening tool under the connector.
      • Pry only on the connector not the socket itself or you risk damage to the motherboard.
      • Carefully lift the connector up away from the socket to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Q302L Display Replacement: adım 6, 2 resimden 1. ASUS Q302L Display Replacement: adım 6, 2 resimden 2.
      • Once the screws and connector are removed, simply pull out the battery from its place.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS Q302L Display Replacement, Display: adım 7, 2 resimden 1. ASUS Q302L Display Replacement, Display: adım 7, 2 resimden 2.
      • Use a Phillips #00 screw driver to remove the five 10mm screws at the hinges.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Q302L Display Replacement: adım 8, 3 resimden 1. ASUS Q302L Display Replacement: adım 8, 3 resimden 2. ASUS Q302L Display Replacement: adım 8, 3 resimden 3.
      • Peel back the tape and remove the two connectors.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Q302L Display Replacement: adım 9, 2 resimden 1. ASUS Q302L Display Replacement: adım 9, 2 resimden 2.
      • Pull up on the black tab to remove the connector that connects to the motherboard.
      • Unplug the hard drive cable from the hard drive.
      • Carefully remove the cables from the track that they run through.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS Q302L Display Replacement: adım 10, 2 resimden 1. ASUS Q302L Display Replacement: adım 10, 2 resimden 2.
      • Carefully remove the display from the rest of the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicholas Lozier
302 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Harley Spring 2019 IUPUI, Team S2-G4, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S2G4
3 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 58
Her zaman: 1,578
