Ana içeriğe geç
ASUS Q302L Fan Replacement
Neye ihtiyacın var
  1. ASUS Q302L Fan Replacement, Back Case: adım 1, 1 resimden 1.
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Fan Replacement: adım 2, 3 resimden 1. ASUS Q302L Fan Replacement: adım 2, 3 resimden 2. ASUS Q302L Fan Replacement: adım 2, 3 resimden 3.
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Fan Replacement: adım 3, 1 resimden 1.
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Fan Replacement, Fan: adım 4, 2 resimden 1. ASUS Q302L Fan Replacement, Fan: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  5. ASUS Q302L Fan Replacement: adım 5, 3 resimden 1. ASUS Q302L Fan Replacement: adım 5, 3 resimden 2. ASUS Q302L Fan Replacement: adım 5, 3 resimden 3.
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  6. ASUS Q302L Fan Replacement: adım 6, 2 resimden 1. ASUS Q302L Fan Replacement: adım 6, 2 resimden 2.
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
Sonuç
Kerolus Gerges
219 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S13-G4, Cagle Spring 2017 USF Tampa, Team S13-G4, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S13G4
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 787
