Giriş
This is a guide to replace the motherboard of your ASUS Q302L laptop. You may need to replace your motherboard if you determine that is the faulty component of your laptop. The first thing you’ll need is a grounding strap and grounding mat. These are to ensure that you do not damage your new motherboard or other components on your laptop while replacing the motherboard. You will also need a small Phillips #00 screwdriver, a small flat head screwdriver, and a prying tool.
Neye ihtiyacın var
Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
Peel back the adhered strip to expose the black and white connections.
Pop the connections off the fixtures.
2 farklı kişi bu kılavuzu tamamladı.
