Ana içeriğe geç
ASUS Q324UA-BHI7T17 Track Pad Replacement
Neye ihtiyacın var
  1. ASUS Q324UA-BHI7T17 Track Pad Replacement, Track Pad: adım 1, 2 resimden 1. ASUS Q324UA-BHI7T17 Track Pad Replacement, Track Pad: adım 1, 2 resimden 2.
    • Remove all ten 5mm screws from the backplate using a Phillips #0 Screwdriver.
  2. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 2, 1 resimden 1.
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 3, 1 resimden 1.
    • Lift up the back plate and slide it to the back of the computer to remove.
  4. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 4, 3 resimden 1. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 4, 3 resimden 2. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the battery from the laptop in the upper left side of the battery, using tweezers.
  5. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 5, 1 resimden 1.
    • Remove the six 5 mm screws holding the battery using a Phillips #0 screwdriver.
  6. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 6, 1 resimden 1.
    • Carefully remove the battery using the plastic opening tool.
  7. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 7, 3 resimden 1. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 7, 3 resimden 2. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 7, 3 resimden 3.
    • Disconnect the trackpad from the motherboard using tweezers.
    • The white tab flips up.
  8. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 8, 2 resimden 1. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 8, 2 resimden 2.
    • Remove the two 5mm screws holding in the trackpad using a Phillips #0 screwdriver.
  9. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 9, 2 resimden 1. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 9, 2 resimden 2.
    • Remove adhesive tape tethering the trackpad to the motherboard with tweezers.
  10. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 10, 3 resimden 1. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 10, 3 resimden 2. ASUS Q324UA-BHI7T17 Track Pad Replacement: adım 10, 3 resimden 3.
    • Carefully remove the trackpad using the plastic opening tool.
    • Lift up and side track toward the back of the computer to remove.
Sonuç
Gabriel survance
343 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Spring 2019 IUPUI, Team S2-G2, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S2G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 188
