Ana içeriğe geç
ASUS Q400A-BHI7N03 Battery Replacement
  1. ASUS Q400A-BHI7N03 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 Battery Replacement: adım 2, 1 resimden 1.
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 Battery Replacement: adım 3, 2 resimden 1. ASUS Q400A-BHI7N03 Battery Replacement: adım 3, 2 resimden 2.
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
Sonuç
To reinsert your battery, follow these instructions in reverse order. Remember to re-lock the tab in step 2.
Matthew Gold
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-4, Rodger Winter 2017 UC Davis, Team 1-4, Rodger Winter 2017 üyesi
UCD-RODGER-W17S1G4
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 675
