Ana içeriğe geç
ASUS Q400A-BHI7N03 Key Replacement
Neye ihtiyacın var
  1. ASUS Q400A-BHI7N03 Key Replacement, Key: adım 1, 1 resimden 1.
    • To remove a key, insert the opening tool in the small gap at the top right corner of the key.
    • Pry off the key by pulling the tool up until the key pops off.
    • If the key is still connected at the bottom, wiggle the key from side to side until it comes off.
  2. ASUS Q400A-BHI7N03 Key Replacement: adım 2, 2 resimden 1. ASUS Q400A-BHI7N03 Key Replacement: adım 2, 2 resimden 2.
    • If there is dirt under the key, use an air canister to clean it up.
    • Do not use any liquids to clean.
  3. ASUS Q400A-BHI7N03 Key Replacement: adım 3, 1 resimden 1.
    • To put the key back in, line it up with the area it came from and push it back in. There will be an audible click when it is correctly inserted.
Bitiş Çizgisi
Matthew Gold
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UC Davis, Team 1-4, Rodger Winter 2017 UC Davis, Team 1-4, Rodger Winter 2017 üyesi
UCD-RODGER-W17S1G4
5 Üyeler
Bir Yorum
Some keys seem to also have a metal bracket under them that need to be strung in when re-inserting the key. Maybe add some instruction for that.
Kevin Low - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 382
