Ana içeriğe geç
ASUS Q524U Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS Q524U Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
  2. ASUS Q524U Hard Drive Replacement: adım 2, 3 resimden 1. ASUS Q524U Hard Drive Replacement: adım 2, 3 resimden 2. ASUS Q524U Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
  3. ASUS Q524U Hard Drive Replacement: adım 3, 1 resimden 1.
    • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
  4. ASUS Q524U Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the back panel, exposing the motherboard.
    • Set the panel aside, skin up to avoid scratches.
  5. ASUS Q524U Hard Drive Replacement: adım 5, 1 resimden 1.
    • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
    • The hard-drive is located in the bottom left corner of the motherboard.
  6. ASUS Q524U Hard Drive Replacement: adım 6, 2 resimden 1. ASUS Q524U Hard Drive Replacement: adım 6, 2 resimden 2.
    • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 53
Her zaman: 4,064
