Ana içeriğe geç
ASUS Q536F Battery Replacement
Neye ihtiyacın var
    1. ASUS Q536F Battery Replacement, Back Panel: adım 1, 2 resimden 1. ASUS Q536F Battery Replacement, Back Panel: adım 1, 2 resimden 2.
      • Remove ten 2 mm screws using a Phillips #0 screwdriver.
      • Remove the screw in the center using a T4 Torx screwdriver.
      • Use an iFixit opening tool to pry open the back panel.
      • It's normal to hear some cracking, but proceed with caution.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS Q536F Battery Replacement, Battery: adım 2, 2 resimden 1. ASUS Q536F Battery Replacement, Battery: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the four 2 mm screws from the battery using a Phillips #1 screwdriver.
      • Detach the battery cable from the motherboard using a pair of tweezers.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Q536F Battery Replacement: adım 3, 3 resimden 1. ASUS Q536F Battery Replacement: adım 3, 3 resimden 2. ASUS Q536F Battery Replacement: adım 3, 3 resimden 3.
      • Unhinge the fan cable using your fingers or a pair of tweezers.
      • Remove the battery from its slot.
      • There should be no resistance from any cable wiring at this point. If there happens to be resistance, make sure to double check and confirm nothing is being pulled.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
vanessa galvez
109 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 88-8, Gonzalez Fall 2023 Gateway, Team 88-8, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S88G8
5 Üyeler
54 adet Kılavuz yazıldı
1Rehber Yorum
Thank you so much!
Vincent - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 58
Her zaman: 3,061
