Ana içeriğe geç
ASUS Q536F Fan Replacement
Neye ihtiyacın var
  1. ASUS Q536F Fan Replacement, Back Panel: adım 1, 2 resimden 1. ASUS Q536F Fan Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Fan Replacement, Fan: adım 2, 2 resimden 1. ASUS Q536F Fan Replacement, Fan: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
    • Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
    • Warped Screw
    • Heatsink shown has warped screw, so unable to remove
  3. ASUS Q536F Fan Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect white and black antennae cables.
    • Using tweezers for this would be helpful.
  4. ASUS Q536F Fan Replacement: adım 4, 2 resimden 1. ASUS Q536F Fan Replacement: adım 4, 2 resimden 2.
    • Disconnect fan cables pulling outwards as shown.
  5. ASUS Q536F Fan Replacement: adım 5, 3 resimden 1. ASUS Q536F Fan Replacement: adım 5, 3 resimden 2. ASUS Q536F Fan Replacement: adım 5, 3 resimden 3.
    • Carefully lift heatsink upward using a Ifixit opening tool or Fingers pull fan out from under the heat sink.
    • The fan can be removed without removing the heatsink, although it may be easier to remove.
Sonuç
Adra Ledward
557 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 88-8, Gonzalez Fall 2023 Gateway, Team 88-8, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S88G8
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 107
