Ana içeriğe geç
ASUS Q536F Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS Q536F Hard Drive Replacement, Back Panel: adım 1, 2 resimden 1. ASUS Q536F Hard Drive Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Hard Drive Replacement, Hard Drive: adım 2, 2 resimden 1. ASUS Q536F Hard Drive Replacement, Hard Drive: adım 2, 2 resimden 2.
    • Disconnect the white ribbon cable from the connection lever using a Jimmy.
  3. ASUS Q536F Hard Drive Replacement: adım 3, 2 resimden 1. ASUS Q536F Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using the Jimmy, lift the hard drive out of its slot.
Sonuç
Adra Ledward
557 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 88-8, Gonzalez Fall 2023 Gateway, Team 88-8, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S88G8
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 85
