Giriş
When replacing a motherboard, it's crucial to select a compatible replacement and consider factors like form factor, chipset, and socket type. Additionally, users should ensure they have proper technical knowledge or seek professional assistance, as motherboard replacements can be complex and may require transferring components from the old motherboard to the new one.
Neye ihtiyacın var
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
Remove the four 2 mm screws from the battery using a Phillips #1 screwdriver.
Detach the battery cable from the motherboard using a pair of tweezers.
Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
Warped Screw
Disconnect the white ribbon cable from the connection lever using a Jimmy.
Use a Phillips #0 screwdriver to remove the four 2 mm screws that secure the motherboard.
