Ana içeriğe geç
ASUS Q536F SSD Replacement
Neye ihtiyacın var
  1. ASUS Q536F SSD Replacement, Back Panel: adım 1, 2 resimden 1. ASUS Q536F SSD Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F SSD Replacement, SSD: adım 2, 1 resimden 1.
    • Remove the single 2 mm screw from the SSD with a Phillips #0 screwdriver.
  3. ASUS Q536F SSD Replacement: adım 3, 1 resimden 1.
    • Pull the SSD out of its slot.
Sonuç
To reassemble your device, Follow these instructions in reverse order.
Adra Ledward
557 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 88-8, Gonzalez Fall 2023 Gateway, Team 88-8, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S88G8
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 122
