Ana içeriğe geç
ASUS Q536F Screen Replacement
Neye ihtiyacın var
  1. ASUS Q536F Screen Replacement, Back Panel: adım 1, 2 resimden 1. ASUS Q536F Screen Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Screen Replacement, Display Assembly: adım 2, 1 resimden 1.
    • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
  3. ASUS Q536F Screen Replacement: adım 3, 3 resimden 1. ASUS Q536F Screen Replacement: adım 3, 3 resimden 2. ASUS Q536F Screen Replacement: adım 3, 3 resimden 3.
    • Using your fingers, unplug the two power cables connecting the display to the motherboard.
    • Remove the display assembly from the laptop.
  4. ASUS Q536F Screen Replacement, Screen: adım 4, 3 resimden 1. ASUS Q536F Screen Replacement, Screen: adım 4, 3 resimden 2. ASUS Q536F Screen Replacement, Screen: adım 4, 3 resimden 3.
    • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
    • Use an iOpener to help loosen the adhesive on the screen.
    • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
    • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
  5. ASUS Q536F Screen Replacement: adım 5, 1 resimden 1.
    • Carefully remove the screen from the rest of the display.
    • The new screen should come with the sticky adhesive.
Sonuç
Adra Ledward
557 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 88-8, Gonzalez Fall 2023 Gateway, Team 88-8, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S88G8
5 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 124
