Giriş
Batteries in laptops tend to die out early, especially the lower-end laptops. Doing this replacement will allow your computer to have more longevity. This guide aims to replace the battery for an ASUS R554L laptop. Make sure that you are working in a well-lit open area. After the battery swap, make sure to test to ensure it's working correctly. To do this, leave the charger in overnight to ensure that the battery is holding a charge.
Neye ihtiyacın var
Flip the laptop so the bottom is facing upward.
Remove ten screws using a Phillips #0 screwdriver.
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
Bir başkası bu kılavuzu tamamladı.
