Ana içeriğe geç
ASUS R554L Battery Replacement
Neye ihtiyacın var
    1. ASUS R554L Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Flip the laptop so the bottom is facing upward.
      • Remove ten screws using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS R554L Battery Replacement: adım 2, 3 resimden 1. ASUS R554L Battery Replacement: adım 2, 3 resimden 2. ASUS R554L Battery Replacement: adım 2, 3 resimden 3.
      • Using your fingertips, carefully pull the backplate in an upright direction.
      • Continue along the edges until the backplate is fully removed.
      • It's normal to hear cracking while pulling up on the plate.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS R554L Battery Replacement: adım 3, 3 resimden 1. ASUS R554L Battery Replacement: adım 3, 3 resimden 2. ASUS R554L Battery Replacement: adım 3, 3 resimden 3.
      • Remove the four screws from the battery using a Phillips #0 screwdriver.
      • Pull up on the cable connected to the motherboard to remove.
      • Remove the battery from the bay.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS R554L Battery Replacement: adım 4, 3 resimden 1. ASUS R554L Battery Replacement: adım 4, 3 resimden 2. ASUS R554L Battery Replacement: adım 4, 3 resimden 3.
      • Place the new battery in the bay.
      • Install the battery cable to the motherboard, applying pressure in a downward direction.
      • Screws the screws back in using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    5. ASUS R554L Battery Replacement: adım 5, 3 resimden 1. ASUS R554L Battery Replacement: adım 5, 3 resimden 2. ASUS R554L Battery Replacement: adım 5, 3 resimden 3.
      • Align the backplate.
      • Starting with the upper right corner, apply pressure in a downward angle.
      • Repeat the process around the backplate until it's fully secure.
      FixBot'a Sor
      Yorum Ekle
    6. ASUS R554L Battery Replacement: adım 6, 2 resimden 1. ASUS R554L Battery Replacement: adım 6, 2 resimden 2.
      • Screw the backplate screws back in using a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
3 farklı kişi bu kılavuzu tamamladı.
Joshua Chavez
214 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 34
Son 30 gün: 168
Her zaman: 8,186
