Ana içeriğe geç
ASUS ROG G46VW Motherboard Replacement
Neye ihtiyacın var
  1. ASUS ROG G46VW Motherboard Replacement, RAM: adım 1, 2 resimden 1. ASUS ROG G46VW Motherboard Replacement, RAM: adım 1, 2 resimden 2.
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  2. ASUS ROG G46VW Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  3. ASUS ROG G46VW Motherboard Replacement: adım 3, 2 resimden 1. ASUS ROG G46VW Motherboard Replacement: adım 3, 2 resimden 2.
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  4. ASUS ROG G46VW Motherboard Replacement: adım 4, 1 resimden 1.
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  5. ASUS ROG G46VW Motherboard Replacement: adım 5, 1 resimden 1.
    • Repeat steps 3-4 to remove the second RAM stick.
  6. ASUS ROG G46VW Motherboard Replacement, Speaker Cover: adım 6, 1 resimden 1.
    • Gently pry the back hinge cover piece away from the device.
  7. ASUS ROG G46VW Motherboard Replacement: adım 7, 1 resimden 1.
    • Disconnect the speaker cable from the motherboard.
  8. ASUS ROG G46VW Motherboard Replacement, Keyboard: adım 8, 1 resimden 1.
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Motherboard Replacement: adım 9, 1 resimden 1.
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Motherboard Replacement: adım 10, 1 resimden 1.
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Motherboard Replacement: adım 11, 1 resimden 1.
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Motherboard Replacement: adım 12, 2 resimden 1. ASUS ROG G46VW Motherboard Replacement: adım 12, 2 resimden 2.
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Motherboard Replacement, Screen: adım 13, 2 resimden 1. ASUS ROG G46VW Motherboard Replacement, Screen: adım 13, 2 resimden 2.
    • Remove screws from silver braces.
  14. ASUS ROG G46VW Motherboard Replacement: adım 14, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove golden screw caps.
  15. ASUS ROG G46VW Motherboard Replacement: adım 15, 1 resimden 1.
    • Remove tape and gently pull up on golden cap connectors to disconnect them.
  16. ASUS ROG G46VW Motherboard Replacement: adım 16, 1 resimden 1.
    • Gently pull the white connector until it comes loose.
  17. ASUS ROG G46VW Motherboard Replacement, Indicator Lights: adım 17, 1 resimden 1.
    • With the motherboard exposed, locate the Indicator Lights and their white plastic housing piece.
  18. ASUS ROG G46VW Motherboard Replacement: adım 18, 1 resimden 1.
    • Remove all 3 screws from the motherboard connection using the Phillips #0 screwdriver.
    • Pull the plastic white housing piece away from the case.
  19. ASUS ROG G46VW Motherboard Replacement: adım 19, 1 resimden 1.
    • Locate the flat LED cable that connects the lights to the motherboard.
    • Flip the black cover upwards before pulling on the cable.
    • Repeat for the other connector piece.
  20. ASUS ROG G46VW Motherboard Replacement, Motherboard: adım 20, 1 resimden 1.
    • Locate and remove the screws.
    • Removing the screws allows you to lift up the motherboard
  21. ASUS ROG G46VW Motherboard Replacement: adım 21, 1 resimden 1.
    • After lifting the motherboard up you can replace any component on it, such as the fans.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 2,019
