Ana içeriğe geç
ASUS ROG G46VW Screen Replacement
Neye ihtiyacın var
  1. ASUS ROG G46VW Screen Replacement, Speaker Cover: adım 1, 1 resimden 1.
    • Gently pry the back hinge cover piece away from the device.
  2. ASUS ROG G46VW Screen Replacement: adım 2, 1 resimden 1.
    • Disconnect the speaker cable from the motherboard.
  3. ASUS ROG G46VW Screen Replacement, RAM: adım 3, 2 resimden 1. ASUS ROG G46VW Screen Replacement, RAM: adım 3, 2 resimden 2.
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  4. ASUS ROG G46VW Screen Replacement: adım 4, 1 resimden 1.
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  5. ASUS ROG G46VW Screen Replacement: adım 5, 2 resimden 1. ASUS ROG G46VW Screen Replacement: adım 5, 2 resimden 2.
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  6. ASUS ROG G46VW Screen Replacement: adım 6, 1 resimden 1.
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  7. ASUS ROG G46VW Screen Replacement: adım 7, 1 resimden 1.
    • Repeat steps 3-4 to remove the second RAM stick.
  8. ASUS ROG G46VW Screen Replacement, Keyboard: adım 8, 1 resimden 1.
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Screen Replacement: adım 9, 1 resimden 1.
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Screen Replacement: adım 10, 1 resimden 1.
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Screen Replacement: adım 11, 1 resimden 1.
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Screen Replacement: adım 12, 2 resimden 1. ASUS ROG G46VW Screen Replacement: adım 12, 2 resimden 2.
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Screen Replacement, Screen: adım 13, 2 resimden 1. ASUS ROG G46VW Screen Replacement, Screen: adım 13, 2 resimden 2.
    • Remove screws from silver braces.
  14. ASUS ROG G46VW Screen Replacement: adım 14, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to remove golden screw caps.
  15. ASUS ROG G46VW Screen Replacement: adım 15, 1 resimden 1.
    • Remove tape and gently pull up on golden cap connectors to disconnect them.
  16. ASUS ROG G46VW Screen Replacement: adım 16, 1 resimden 1.
    • Gently pull the white connector until it comes loose.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 502
