Ana içeriğe geç
ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement, Internal Hard Drive: adım 1, 1 resimden 1.
    • Remove the six screws on the back of the laptop using a Phillips screwdriver.
    • Remove the back casing being held on by the one single screw. First lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
  2. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: adım 2, 2 resimden 1. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: adım 2, 2 resimden 2.
    • Locate the metal hard drive bay in the bottom left corner of the laptop.
    • Remove the two black screws securing the metal hard drive to the plastic.
    • Pull the tab to the right and slide to unseat the hard drive bay, then lift out.
  3. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: adım 3, 2 resimden 1. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the two screws on the sides of the hard drive panel, shown circled. Repeat for the other side.
    • Replace the hard drive.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Logan Smith
783 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-3, Banghart Winter 2017 Cal Poly, Team 8-3, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G3
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 994
