Ana içeriğe geç
ASUS ROG Strix GL503VD-DB71 Fan Replacement
Neye ihtiyacın var
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: adım 1, 3 resimden 1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: adım 1, 3 resimden 2. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: adım 1, 3 resimden 3.
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: adım 2, 3 resimden 1. ASUS ROG Strix GL503VD-DB71 Fan Replacement: adım 2, 3 resimden 2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: adım 2, 3 resimden 3.
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: adım 3, 3 resimden 1. ASUS ROG Strix GL503VD-DB71 Fan Replacement: adım 3, 3 resimden 2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: adım 3, 3 resimden 3.
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - Yanıt
WTF i can find a 12 V for my GL503V
mrparisalexandre - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 4,648
