Ana içeriğe geç
ASUS ROG Zephyrus M15GU205L Display Cable Replacement
Neye ihtiyacın var
  1. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Battery: adım 1, 2 resimden 1. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Battery: adım 1, 2 resimden 2.
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: adım 2, 2 resimden 1. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: adım 3, 1 resimden 1.
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: adım 4, 2 resimden 1. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: adım 5, 1 resimden 1.
    • Remove the battery from the computer.
  6. ASUS ROG Zephyrus M15GU205L Display Cable Replacement, Display Cable: adım 6, 1 resimden 1.
    • Once the back has been removed, locate this connection cable.
    • Check to see if the connector is in the pin slot; if not, locate the connector.
  7. ASUS ROG Zephyrus M15GU205L Display Cable Replacement: adım 7, 1 resimden 1.
    • If the connection is loose, connect the pins into the slot.
    • Once the connector is connected, do these steps in reverse.
Sonuç
Yahir Donis
339 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 69-69, Gonzalez Fall 2023 Gateway, Team 69-69, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S69G69
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 225
