Ana içeriğe geç
ASUS ROG Zephyrus M15GU205L Fan Cleaning
Neye ihtiyacın var
  1. ASUS ROG Zephyrus M15GU205L Fan Cleaning, Battery: adım 1, 2 resimden 1. ASUS ROG Zephyrus M15GU205L Fan Cleaning, Battery: adım 1, 2 resimden 2.
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 2, 2 resimden 1. ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 2, 2 resimden 2.
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 3, 1 resimden 1.
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 4, 2 resimden 1. ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 5, 1 resimden 1.
    • Remove the battery from the computer.
  6. ASUS ROG Zephyrus M15GU205L Fan Cleaning, ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 6, 2 resimden 1. ASUS ROG Zephyrus M15GU205L Fan Cleaning, ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 6, 2 resimden 2.
    Microfiber Cleaning Cloths
    $3.99
    Satın Al
    • Use the microfiber cloth to wipe any surface dust off the fan fins.
    • Wipe lightly as to not push any of the dust inside.
    • Wiping off the dust is optional.
  7. ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 7, 2 resimden 1. ASUS ROG Zephyrus M15GU205L Fan Cleaning: adım 7, 2 resimden 2.
    • Use the compressed air to blow out the dust from the fan.
    • Use the information on how to correctly use the product you selected.
    • Use the air until you see the results you are comfortable with.
Sonuç
eli2243977
281 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 69-69, Gonzalez Fall 2023 Gateway, Team 69-69, Gonzalez Fall 2023 üyesi
GCC-GONZALEZ-F23S69G69
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 31
Son 30 gün: 103
Her zaman: 377
