Ana içeriğe geç
ASUS TUF Gaming FX505DY Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS TUF Gaming FX505DY Hard Drive Replacement, Back Case: adım 1, 1 resimden 1.
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 2, 2 resimden 1. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 3, 2 resimden 1. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 3, 2 resimden 2.
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 4, 2 resimden 1. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 4, 2 resimden 2.
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 1. ASUS TUF Gaming FX505DY Hard Drive Replacement, Hard Drive: adım 5, 2 resimden 2.
    • Remove the two 6 mm screws holding the hard drive enclosure in place using a Phillips #1 screwdriver.
  6. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 6, 3 resimden 1. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 6, 3 resimden 2. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 6, 3 resimden 3.
    • Slide the enclosure away from the motherboard slot to unplug the hard drive, then remove the drive and enclosure from the device.
  7. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 7, 3 resimden 1. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 7, 3 resimden 2. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 7, 3 resimden 3.
    • Remove the three screws holding the hard drive in the enclosure. The screws in the images are 4 mm Phillips #2, although screw size may vary.
  8. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 8, 2 resimden 1. ASUS TUF Gaming FX505DY Hard Drive Replacement: adım 8, 2 resimden 2.
    • The hard drive should move in the enclosure and can be freely removed.
Sonuç
Benyamin Claxton
872 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S2G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 565
