Ana içeriğe geç
ASUS TUF Gaming FX505DY RAM Replacement
Neye ihtiyacın var
  1. ASUS TUF Gaming FX505DY RAM Replacement, Back Case: adım 1, 1 resimden 1.
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY RAM Replacement: adım 2, 2 resimden 1. ASUS TUF Gaming FX505DY RAM Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY RAM Replacement: adım 3, 2 resimden 1. ASUS TUF Gaming FX505DY RAM Replacement: adım 3, 2 resimden 2.
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY RAM Replacement: adım 4, 2 resimden 1. ASUS TUF Gaming FX505DY RAM Replacement: adım 4, 2 resimden 2.
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY RAM Replacement, RAM: adım 5, 2 resimden 1. ASUS TUF Gaming FX505DY RAM Replacement, RAM: adım 5, 2 resimden 2.
    • Pull the motherboard clips away from the sides of the RAM chip.
    • The RAM chip will pop up at an angle.
  6. ASUS TUF Gaming FX505DY RAM Replacement: adım 6, 1 resimden 1.
    • At an angle, gently but firmly pull the RAM chip to remove it from the slot.
    • To install RAM, insert the RAM into the slot and press flat until the clips make an audible "click."
Sonuç
Carter Owen
169 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Mellen Spring 2022 UMass Dartmouth, Team 2-4, Mellen Spring 2022 üyesi
UMASSD-MELLEN-S22S2G4
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 13
Son 30 gün: 36
Her zaman: 1,014
